MX 18.210 OS notes
sjlee
MX 18.210 OS notes
Dear
I checked meraki MX OS release note and I saw this message in Known Issues.
  • The Non-Meraki VPN service may fail to properly establish IKEv2 tunnels when the MX appliance is acting as the IKEv2 responder and many allowed subnets are configured.
In above context,,,
1) "many allowed subnets are configured" -> Is this mean there are many subnets in Private subnets??
2) "The Non-Meraki VPN service may fail to properly establish IKEv2 tunnels" -> Is this mean It may unstable Non-Meraki VPN tunnel connection and may occur repeatly many Non-Meraki VPN SA event log (down/up) ?
Is my understanding correct?
I appreciate anyone answer If know.
Thank you.
Yes, it's correct.
sjlee
Thank you for reply.
Because I'm just wondering.. For example, IKE version is 1 and there are many subnets in Private subnets. Even in this case, can it be included in the above?
Brash
Yes, it is referring to the number of advertised private subnetes
This I'm not sure.
If you believe you're hitting this issue, you may be better asking Merkai support as they can check internal bug notes and logs to confirm whether you're hitting this issue or not.
sjlee
