We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hello Everyone,
Can I connect LAN2 of MX105-01 to LAN2 MX105-02 for warm spare or I create vlan transit form core switch to MX?
Thanks you all
Viet Ton
Solved! Go to solution.
Its recommended to connect it to downstream switch(es)
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Deployment_Guides/MX_Warm_S...
Thanks you
