* its operation
* advantages
* the license is sold with the equipment ?
* web caching
Solved! Go to Solution.
The appliance will not work - at all - without a licence.
On the whole, transparent web caching is a useless technology these days. Most content is not cache-able. On the whole I would not advise clients to use web caching.
The MX82 is no longer a current model. This is the spec sheet for the current MX84:
https://meraki.cisco.com/products/appliances/mx84
You can read about MX's in general at this page:
You can buy either an "Enterprise" licence which does basic firewall and SDWAN, or an "Advanced Security" licence which enables malware scanning, content filtering, etc. There is a more detailed break down:
Hi
I understand Cisco Meraki does not have any MX-82 Model as of now. The nearest I can think of is MX 84 which available for now.
MX 84 is a security appliance (UTM).
It offers various services like Web Caching, VPN Server, DHCP Server, VLANs, Content Filtering, L3 & L7 Firewall and many more.... The device can be configured with various features depending on your requirement or network topology.
The following url gives us detailed information about the product
You may also watch Fady's exclusive video on MXes available on Youtube to understand the function of Product.
https://www.youtube.com/channel/UCrVdn6BYNPPQSILwKY3hUqQ/videos
All products of Cisco Meraki requires a cloud license to work. You may buy the same along with the Product or may be buy it separately.
Hi
As Philip suggests "Cisco Meraki do not work with out License".
However the solution is extremely awesome from the point of Analytics.
It gives you in depth information about how the network is utilized. This information is very useful to define and decide
What to be allowed? What to be blocked"
Who should have more bandwidth?
What applications and services to be allowed to users selectively and at what speed?
To summarize the network utilization can be shaped so that the resources can be used for productive purposes.
Incase you have budget challenges you may start with Enterprise license and upgrade to Advanced (However Advanced is recommended)
Kindly find the following url to see the difference between the Enterprise and Advanced License.
