MA-SFP-1GB-TX module in WAN 1 / 2 of MX95
Holli69
we have a Multi WAN Setup, ISP 1 on MA-SFP-1GB-TX WAN1, ISP 2 on MA-SFP-1GB-TX WAN2, ISP 3 on WAN4 as Backup.
We have observed, that WAN 1+2 fails on come up (up only for a shot time) due to halfduplex (1/10G on local Status page, 1G fixed is the same problem), so the Site comes online with Backup WAN 4 (mGig Port).
Has anyone the same issue with MA-SFP-1GB-TX module in WAN Port 1/2 with Halfdulex ? I think, this is the reason why WAN 1/2 don't come online (should be fullduplex)
RWelch
What MX firmware are you running?  Auto detect is preferred unless there is a compelling reason to change the speed/duplex.
Duplex mismatches affecting physical link speed
When interconnecting two Ethernet peers, Meraki recommends using auto-negotiation, which allows Ethernet peers to exchange link speed and duplex information.
Explanation:
Ethernet peers use electrical signals to determine when a link is established. These electrical pulses make up a 16-bit word defining the speed and duplex for auto-negotiation.  If the speed and duplex of one peer must be manually set, it is important to set the other peer with the same settings.
Holli69
Hi @RWelch
we are on MX 19.1.11
RWelch
Your post didn't indicate what speed and duplex the WAN interfaces configured for (normally set to AUTO)?
By chance, have you changed either WAN interface from the default (AUTO) to something else?  And if so, did you manually change the other end to match the same speed and duplex you manually configured on the MX device?
And if you'd somehow rather not say, then perhaps a tech can help you navigate all of this with a support case.
