Login dashboard based on region
Dear Expert ,
As i want my dashboard to login based on region , can we do it ?
As i only see options based on source ip address , such as public ip address not based on region ,
For example , i only want china region can login to my org , other location from china , cannot.
can we do it ?
Accepted Solutions
Re: Login dashboard based on region
It's built-in, use the link that @PhilipDAth provided to learn how to configure this.
Note: If you're not based in the United States, United Kingdom, Canada, Mexico, France, Spain, Italy, or Germany; SMS 2FA codes are not fully supported due to carrier support and are sent as best effort, so please instead use 2FA With Google Authenticator, which you can learn how to do so using this link: https://documentation.meraki.com/zGeneral_Administration/Other_Topics/Two-Factor_Authentication#Usin...
10 REPLIES 10
Source IP is the only way to restrict this, other than splitting your Dashboard into separate organisations and managing which users have access to which organisation. Otherwise, it's a feature request.
If you want to improve your dashboard login security consider using 2 factor authentication.
Hi Expert ,
Is 2factor need extra license for dashboard or we can use build-in ?
Thanks for this , Brother
Add Multi Factor Auth using Cisco DUO and get the added layer of security and have Geolocation based policies in place 😎
https://duo.com/docs/meraki
Great shout, @CptnCrnch.
I'm not sure if the free level of Duo allows this (I know where are some limitations with policies etc) but it's worth checking out if you have less than 10 users. Otherwise, it's an optional subscription to use Duo.
Natively, without Duo/OpenID you can use:
- Source IP Restriction
- 2FA for increased security (not limiting geolocation however)
Thanks @MerakiConnor. Unfortunately, Geolocation (which are part of the policy part) are not available in the free plan.
unfortunately , i need the free one xD
Using Duo for Meraki Dashboard integration is a little bit more work.  First you have two deploy a Duo Access Gateway appliance (I usually deploy a pair because if you have one and it goes down you can't log in - and then I often use a load balancer to distribute the traffic over them although DNS round robin also works but you need to set a high TTL which then prevents fail over from working as well).
Then you need to configure SAML integration.
