Is there a way to make a redundant link between an MX67W and MS225 to cover port/cable failure?
Solved! Go to Solution.
Mx cant do a LAG.
You can use Spanming tree. If you connect 2 links to a switch. And that switch uses STP the switch will block 1 link.
Spamming Tree , is that a typo or intended pun 😂
Life ain't easy on the phone 😆
View all community news »
\\n\\t\\t\\t\\t\\t\\tSorry, unable to complete the action you requested.\\n\\t\\t\\t\\t\\t<\\/p>\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\t\\t\\t<\\/div>\\n\\n\\t\\t\\t\\n\\t\\t<\\/div>\";LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_9f47253958af08', 'disableAutoComplete', '#ajaxfeedback_9f4725391c03e4_0', 'LITHIUM:ajaxError', {}, '2BvOtoXaLw1LmEDWvpb83qGp7va-h8TAkSCSDJ7OhFs.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":3},"inputSelector":"#messageSearchField_9f4725391c03e4_0","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.messagesearchfield.messagesearchfield:autocomplete?t:ac=board-id/security/thread-id/37853&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_9f472539ddf617', 'disableAutoComplete', '#ajaxfeedback_9f4725391c03e4_0', 'LITHIUM:ajaxError', {}, 'nlrxDN8mqWOs2fPJem_Db-7qdjCk1hLAnstv58KmATc.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":3},"inputSelector":"#messageSearchField_9f4725391c03e4_1","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.tkbmessagesearchfield.messagesearchfield:autocomplete?t:ac=board-id/security/thread-id/37853&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.Placeholder(); LITHIUM.AutoComplete({"options":{"triggerTextLength":0,"updateInputOnSelect":true,"loadingText":"Searching for users...","emptyText":"No Matches","successText":"Users found:","defaultText":"Enter a user name or rank","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_9f47253a0a2bd5', 'disableAutoComplete', '#ajaxfeedback_9f4725391c03e4_0', 'LITHIUM:ajaxError', {}, '6r_XPRfV0o2zQMx-O_o1S6SnDdpXnSNr72VjgmkMd5c.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#userSearchField_9f4725391c03e4","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.usersearchfield.usersearchfield:autocomplete?t:ac=board-id/security/thread-id/37853&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:userExistsQuery","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#userSearchField_9f4725391c03e4","action":"userExistsQuery","feedbackSelector":"#ajaxfeedback_9f4725391c03e4_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.usersearchfield:userexistsquery?t:ac=board-id/security/thread-id/37853&t:cp=search/contributions/page","ajaxErrorEventName":"LITHIUM:ajaxError","token":"U09dwGCVbz4wGIdiLYzGsmn2_0QjTOQPWUvavxWQcVA."}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_9f47253a360ba8', 'disableAutoComplete', '#ajaxfeedback_9f4725391c03e4_0', 'LITHIUM:ajaxError', {}, '2xF-KvZfH3Xom0Z3bo7hm9rddmaH19ieF-7QcvTYRvY.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#noteSearchField_9f4725391c03e4_0","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.notesearchfield.notesearchfield:autocomplete?t:ac=board-id/security/thread-id/37853&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_9f47253a60f96b', 'disableAutoComplete', '#ajaxfeedback_9f4725391c03e4_0', 'LITHIUM:ajaxError', {}, 'mKbX2nGjs9qdX03b7zusPK8bJfv2gz4EHA9sWGOaTgo.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#productSearchField_9f4725391c03e4","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.productsearchfield.productsearchfield:autocomplete?t:ac=board-id/security/thread-id/37853&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.Link({"linkSelector":"a.lia-link-ticket-post-action"}); LITHIUM.AjaxSupport.fromLink('#enableAutoComplete_9f4725391c03e4', 'enableAutoComplete', '#ajaxfeedback_9f4725391c03e4_0', 'LITHIUM:ajaxError', {}, 'XXtfAN3NIQysHC6se_D1pJYLvRbfvYeNhCK7jhvT_UM.', 'ajax'); LITHIUM.Tooltip({"bodySelector":"body#lia-body","delay":30,"enableOnClickForTrigger":false,"predelay":10,"triggerSelector":"#link_9f4725391c03e4","tooltipContentSelector":"#link_9f4725391c03e4_0-tooltip-element .content","position":["bottom","left"],"tooltipElementSelector":"#link_9f4725391c03e4_0-tooltip-element","events":{"def":"focus mouseover keydown,blur mouseout keydown"},"hideOnLeave":true}); LITHIUM.SearchAutoCompleteToggle({"containerSelector":"#searchautocompletetoggle_9f4725391c03e4","enableAutoCompleteSelector":".search-autocomplete-toggle-link","enableAutocompleteSuccessEvent":"LITHIUM:ajaxSuccess:enableAutoComplete","disableAutoCompleteSelector":".lia-autocomplete-toggle-off","disableAutocompleteSuccessEvent":"LITHIUM:ajaxSuccess:disableAutoComplete","autoCompleteSelector":".lia-autocomplete-input"}); LITHIUM.SearchForm({"asSearchActionIdSelector":".lia-as-search-action-id","useAutoComplete":true,"selectSelector":".lia-search-form-granularity","useClearSearchButton":false,"buttonSelector":".lia-button-searchForm-action","asSearchActionIdParamName":"as-search-action-id","formSelector":"#lia-searchformV32_9f4725391c03e4","nodesModel":{"tkb|tkb":{"title":"Knowledge base","inputSelector":".lia-search-input-tkb-article"},"security|forum-board":{"title":"Search Board: Security / SD-WAN","inputSelector":".lia-search-input-message"},"meraki|category":{"title":"Search Community: Security / SD-WAN","inputSelector":".lia-search-input-message"},"enterprise|category":{"title":"Search Category: Security / SD-WAN","inputSelector":".lia-search-input-message"},"user|user":{"title":"Users","inputSelector":".lia-search-input-user"}},"asSearchActionIdHeaderKey":"X-LI-AS-Search-Action-Id","inputSelector":"#messageSearchField_9f4725391c03e4_0:not(.lia-js-hidden)","clearSearchButtonSelector":null}); // LITHIUM.DropDownMenu({"menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","menuOpenCssClass":"dropdownHover","clickElementSelector":".lia-js-click-menu","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#pageInformation","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_0","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_0","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity', 'kudoEntity', '#ajaxfeedback', 'LITHIUM:ajaxError', {}, 'LysHrtgecvxGQEji2a1ppjVhL021_Qqfh3CAEA0TsEc.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "149467", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","linearDisplayViewSelector":".lia-linear-display-message-view","renderEventParams":{"replyWrapperId":"replyWrapper","messageId":149467,"messageActionsId":"messageActions"},"threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","isRootMessage":true,"replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions","loaderSelector":"#loader","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer","layoutView":"threaded","replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true,"loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"r0goGz9QWW3BhCaZdUGvLxfXrCxPIfow9Th4qvzrEVc."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"bBNHworcmKsw56MNU09lVG1_CvznPeoObPRmrziGcbc."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "149467", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1101110111111111111110111110100101111101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_2","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_1","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_0', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_0', 'kudoEntity', '#ajaxfeedback_0', 'LITHIUM:ajaxError', {}, 'o953tPp6dynFNQO4IB4Kt5gntp2c4rVkG2D60RfNCjs.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_0", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "149470", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","linearDisplayViewSelector":".lia-linear-display-message-view","renderEventParams":{"replyWrapperId":"replyWrapper_0","messageId":149470,"messageActionsId":"messageActions_0"},"threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","isRootMessage":false,"replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_0","loaderSelector":"#loader","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_0","layoutView":"threaded","replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true,"loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_0","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"G5CY3zv5-LJF9E3l324A1WHaP4YNDp2MTzBMGok9pW0."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_0","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"RItLG9zFNlGKs6WLsDQZnUQkQjK9FdbdBo0Q_VupBK0."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_0", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "149470", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110011111111111110111110100101111101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper","componentSelector":"#threadeddetaildisplaymessageviewwrapper","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":149470,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddisplay_0.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"McQHf8GG56LRiBoBGpRfC6_iE9kuZ_cXQBf-c9quTR8."}); LITHIUM.MessageThreadedDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddisplay_0","rootMessageComponentSelector":"#threadeddisplay_0","editEvent":"LITHIUM:editMessageViaAjax","confirmationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":149467,"expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddisplay_0","action":"renderInlineEditForm","feedbackSelector":"#threadeddisplay_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddisplay_0:renderinlineeditform?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"O4r4Lpfq3s0avDpeOMOuYS6ZgRxkK_8hvCDdxbfRyAA."}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_8","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_2","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_1', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_1', 'kudoEntity', '#ajaxfeedback_1', 'LITHIUM:ajaxError', {}, '4p2EHoSjd0byqt_ihUhl42U6rUaHgmBdnRfPVEl3D5o.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_1", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "149470", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","linearDisplayViewSelector":".lia-linear-display-message-view","renderEventParams":{"replyWrapperId":"replyWrapper_1","messageId":149470,"messageActionsId":"messageActions_1"},"threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","isRootMessage":false,"replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_1","loaderSelector":"#loader","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_1","layoutView":"threaded","replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true,"loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_1","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"-39tNT2yHQyyjMM4swBHL6qOHATXRjg_lUIg1_DmrYI."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_1","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"Jp98E4kVIjOvRzYjbtwDUx8acuSWUQiH-KOAbdGlReg."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_1", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "149470", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper_0","componentSelector":"#threadeddetaildisplaymessageviewwrapper_0","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":149470,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper_0 .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper_0","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"AGw5mygA_cRgZ4TCb51dmwXVDQh9ctqFTg4ZGMgP-dg."}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_9","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_10","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_11","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_3","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_2', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_2', 'kudoEntity', '#ajaxfeedback_2', 'LITHIUM:ajaxError', {}, 'rQuosII0ZYK4_FSWT9Ij_ALBD1V9tAW-YeHDyP3nRVw.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_2", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "149476", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","linearDisplayViewSelector":".lia-linear-display-message-view","renderEventParams":{"replyWrapperId":"replyWrapper_2","messageId":149476,"messageActionsId":"messageActions_2"},"threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","isRootMessage":false,"replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_2","loaderSelector":"#loader","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_2","layoutView":"threaded","replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true,"loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_2","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_2","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"nK1LxuQsl7j-26MXlzBWBir1X0IFEYPWZduT3uJv6r0."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_2","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_2","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"GwP4Yt4Uaec_lnTqtLRjEQPE5n7ntoz7AznVQgtoR9Y."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_2", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "149476", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper_1","componentSelector":"#threadeddetaildisplaymessageviewwrapper_1","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":149476,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper_1 .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper_1","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"Oa7BG1ub6A_3UQq5cij3Mx5Z1UTcKd-ltwHqEitZn7w."}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_12","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_13","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_14","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_4","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_3', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_3', 'kudoEntity', '#ajaxfeedback_3', 'LITHIUM:ajaxError', {}, 'vp9Bt6GyDDI7LgAN3SreN2gFgdilrIb0gcycuXzWWW8.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_3", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "149502", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","linearDisplayViewSelector":".lia-linear-display-message-view","renderEventParams":{"replyWrapperId":"replyWrapper_3","messageId":149502,"messageActionsId":"messageActions_3"},"threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","isRootMessage":false,"replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_3","loaderSelector":"#loader","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_3","layoutView":"threaded","replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true,"loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_3","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_3","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"D6RzDUop7clIaXMMwemKMP_Idtk4co2YzkcHW0S7D8k."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_3","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_3","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/security/thread-id/37853&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"1WgkDL7ViKlJNrosyDE_lvDs8INXxo1FgPnrtgb-hRo."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_3", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "149502", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper_2","componentSelector":"#threadeddetaildisplaymessageviewwrapper_2","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":149502,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper_2 .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper_2","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper_2","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"m6q9MqPeG4XnG14v-S5ENZpDxWewDDvNFR9j5Y0a8Co."}); LITHIUM.ThreadedDetailMessageList({"renderLoadMoreEvent":"LITHIUM:renderLoadMoreMessages","loadingText":"Loading...","placeholderClass":"lia-messages-threadedDetailList-placeholder","loadFetchSelector":"#threadeddetailmessagelist .lia-load-fetch","rootMessageId":149467,"loadPageNumber":1}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderLoadMoreMessages","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#threadeddetailmessagelist .lia-load-fetch","action":"renderLoadMoreMessages","feedbackSelector":"#ajaxFeedback","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist:renderloadmoremessages?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"my3FOnIkKJTuprA03AP0dNVqHoXrV1q1y3Mriwn97Hk."}); LITHIUM.InlineMessageReplyEditor({"openEditsSelector":".lia-inline-message-edit","ajaxFeebackSelector":"#inlinemessagereplyeditor_0 .lia-inline-ajax-feedback","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","topicMessageSelector":".lia-forum-topic-message-gte-5","focusEditor":false,"hidePlaceholderShowFormEvent":"LITHIUM:hidePlaceholderShowForm","formWrapperSelector":"#inlinemessagereplyeditor_0 .lia-form-wrapper","reRenderInlineEditorEvent":"LITHIUM:reRenderInlineEditor","ajaxBeforeSendEvent":"LITHIUM:ajaxBeforeSend:InlineMessageReply","element":"input","clientIdSelector":"#inlinemessagereplyeditor_0","loadAutosaveAction":false,"newPostPlaceholderSelector":".lia-new-post-placeholder","placeholderWrapperSelector":"#inlinemessagereplyeditor_0 .lia-placeholder-wrapper","messageId":149467,"formSelector":"#inlinemessagereplyeditor_0","expandedClass":"lia-inline-message-reply-form-expanded","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","newPostPlaceholderClass":"lia-new-post-placeholder","editorLoadedEvent":"LITHIUM:editorLoaded","replyEditorPlaceholderWrapperCssClass":"lia-placeholder-wrapper","messageActionsClass":"lia-message-actions","cancelButtonSelector":"#inlinemessagereplyeditor_0 .lia-button-Cancel-action","isGteForumV5":true,"messageViewWrapperSelector":".lia-threaded-detail-display-message-view","disabledReplyClass":"lia-inline-message-reply-disabled-reply"}); LITHIUM.Text.set({"ajax.reRenderInlineEditor.loader.feedback.title":"Loading..."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"useLoader":true,"blockUI":"","event":"LITHIUM:reRenderInlineEditor","parameters":{"clientId":"inlinemessagereplyeditor_0"}},"tokenId":"ajax","elementSelector":"#inlinemessagereplyeditor_0","action":"reRenderInlineEditor","feedbackSelector":"#inlinemessagereplyeditor_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.inlinemessagereplyeditor_0:rerenderinlineeditor?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"iQ4RTQwsrqUbE7MPwJVYr8KZt9_lDvCgSHaJDIMSrlY."}); LITHIUM.InlineMessageEditor({"ajaxFeebackSelector":"#inlinemessagereplyeditor_0 .lia-inline-ajax-feedback","submitButtonSelector":"#inlinemessagereplyeditor_0 .lia-button-Submit-action"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadComponent","parameters":{"componentId":"messages.widget.emoticons-lazy-load-runner"}},"tokenId":"ajax","elementSelector":"#inlinemessagereplyeditor_0","action":"lazyLoadComponent","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.inlinemessagereplyeditor_0:lazyloadcomponent?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"Zo4QpuyZaLoAXutoTBD2_6-5_txdvySu6Hh6MhQBGM8."}); LITHIUM.lazyLoadComponent({"selectors":{"elementSelector":"#inlinemessagereplyeditor_0"},"events":{"lazyLoadComponentEvent":"LITHIUM:lazyLoadComponent"},"misc":{"isLazyLoadEnabled":true}}); LITHIUM.Components.renderInPlace('recommendations.widget.recommended-content-taplet', {"componentParams":"{\n \"mode\" : \"slim\",\n \"componentId\" : \"recommendations.widget.recommended-content-taplet\"\n}","componentId":"recommendations.widget.recommended-content-taplet"}, {"errorMessage":"An Unexpected Error has occurred.","type":"POST","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.recommendedcontenttaplet:lazyrender?t:ac=board-id/security/thread-id/37853&t:cp=recommendations/contributions/page"}, 'lazyload'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "sortLabelsWidget", "actions" : [ { "context" : "envParam:viewOrderSpec", "action" : "rerender" } ] } ], "componentId" : "labels.widget.labels.sortable", "initiatorBinding" : false, "selector" : "#labelsTaplet", "parameters" : { "useSortHeader" : "false", "viewOrderSpec" : "oNC1OUgrbIIYS6HomgYuqovLFDoZqzcTSK6SGRvPwq0xwyIUPu2g6Sa-CRpb-SEgS18kUZ49qGCCOdrI4SvVkxuhnIKwbGqtKCJhtJoDWLWgdVCH5j4RLptMW3ddZDNW3beT0pTP49d8BhmMpD2rnZQFdp-qWHk7dYm_Lh0VyaCF4PC5neDVttqjuyoDyTJ23TOq_xQJxaQOCpYNDC6K7T6meGiLbOs0RRbkDFSWHBtYRuDZB-LkJzWzCes1amSl6ybfwY8dz7VVZn1NfQlPimeiCdnLcX4jS-13UByRT2af0kKL3A5cD34Zk4yfT9rg1ktEl7eufjSOVP43IuJYo2VissTrqrgAHkDMYqputFJyoi4L5xodQpAuaWbJQxDBmzX2Nu0iavbrAI6YrWrgFBOcdav2wVJzYIDPtTpGLbJB8bB-7bA7l7rX2R1cVTtdq5_YejFvA9xbJS63kFhZaDRArq02PxR5FMl-W8SpESBZDc7gDXGNyVIAzmmK6GjQHf4UHZBIEu6ozXp9IOJ_QRgi6X9IdOQlEIhSqAQvc0k." }, "initiatorDataMatcher" : "" }); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:sortLabelsWidget","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#labelsTaplet","action":"sortLabelsWidget","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.labelstaplet:sortlabelswidget?t:ac=board-id/security/thread-id/37853&t:cp=labels/contributions/page","ajaxErrorEventName":"LITHIUM:ajaxError","token":"m_dMq7sWnTh0KYxAXG4IMG7llXbqPnhvU9lU1TLJNGw."}); LITHIUM.PartialRenderProxy({"limuirsComponentRenderedEvent":"LITHIUM:limuirsComponentRendered","relayEvent":"LITHIUM:partialRenderProxyRelay","listenerEvent":"LITHIUM:partialRenderProxy"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:partialRenderProxyRelay","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":document,"action":"partialRenderProxyRelay","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.liabase.basebody.partialrenderproxy:partialrenderproxyrelay?t:ac=board-id/security/thread-id/37853","ajaxErrorEventName":"LITHIUM:ajaxError","token":"P-yDoGOfu3awzuSZfzWVcpQnzV3lYLFrW1dm29sLADU."}); LITHIUM.Auth.API_URL = '/t5/util/authcheckpage'; LITHIUM.Auth.LOGIN_URL_TMPL = '/plugins/common/feature/saml/doauth/post?referer=https%3A%2F%2FREPLACE_TEXT'; LITHIUM.Auth.KEEP_ALIVE_URL = '/t5/status/blankpage?keepalive'; LITHIUM.Auth.KEEP_ALIVE_TIME = 300000; LITHIUM.Auth.CHECK_SESSION_TOKEN = 'CLI7N8S9GEhGpf1AiZSGrDlfHZYhVcWW9iVH28nvU44.'; LITHIUM.AjaxSupport.useTickets = false; LITHIUM.Loader.runJsAttached(); // -->
