Link aggregation between MX67W and MS225
alceryes1
Is there a way to make a redundant link between an MX67W and MS225 to cover port/cable failure?
Mx cant do a LAG.
You can use Spanming tree. If you connect 2 links to a switch. And that switch uses STP the switch will block 1 link.
Mx cant do a LAG.
RaphaelL
Spamming Tree , is that a typo or intended pun 😂
Life ain't easy on the phone 😆
