Is it possible to use link aggregation on the uplink in one-arm concentrator mode? We would like to connect an MX-450 to two Nexus's using vPC if that's possible.
Thanks for any replies.
Solved! Go to solution.
Mx does not support lag(lacp) on lan/wan.
And one armed concentrator only works with a single WAN port
https://documentation.meraki.com/MX/Deployment_Guides/VPN_Concentrator_Deployment_Guide#Appendix_1:_...
