We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
i have Meraki MX64 i need to buy license for it. so what license i need to purchase enterprise or advanced??
Solved! Go to solution.
Hi @munaf
I shall suggest go for "Advanced Security License".
You may have look at the following Url (To know the difference between both the License Types)
https://www.syndicateinfo.com/post/what-is-the-difference-between-the-enterprise-and-advanced-securi...
