It is possible to download logs from Meraki MX via dashboard or network?
MakaraMEAS
Dear Community,
I have question, it is possible to download logs from Meraki MX via dashboard or remote network?
As I know we can do when connect to LAN, for troubleshooting or reviews logs.
Thanks,
Makara,
M.MAKARA
If you can't connect to the cloud, you need to use the local status page to see why.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
5 Replies 5
Johnfnadez
Hi!
You can get them from Meraki Dashboard  via APIs
Johnny Fernandez
Network & Security Engineer
CCNP | JNCIP-SEC | CMNA
MakaraMEAS
Can you help provide more detail information?
M.MAKARA
Johnfnadez
Sure!
You can get logs in two different ways,
The first (easier)
Going to the Network-wide tab and then to event log, you can download the sorted logs in a CSV file:
The second way and scalable solution is via API, you can follow this link if you have some coding experience:
https://documenter.getpostman.com/view/7928889/SVmsVg6K?version=latest#1982f77c-5ee6-49da-94f4-ee1a2...
I hope this information can be useful for you 🙂
Johnny Fernandez
MakaraMEAS
I think it is not about local logs, something like need to troubleshoot why it cannot up to the cloud.
M.MAKARA
