Is there any way to see how many /xx we have left of a /yy when using templates with Unique IPs
thomasthomsen
We are deploying a lot of small networks on Z3's and everything is fine.
We have configured them for unique addressing, and have a /27 for each site from a bog pool of a /18.
But, I cant quite find anywhere where I can see how many addresses are left in the /18 pool.
Is there a UI representation somewhere in the dashboard ?
Or, can I API "it" ?
Thanks in advance.
/Thomas
You can have a total of 512 unique /27 networks in a /18 subnet.  Therefore a simple count should let you know how many you have left, unless some overlap...
thomasthomsen
Yes , I know that 🙂 , but the customer might not have that kind of knowledge (read: managers).
So I was just asking if anyone knows if Im missing a "spot" in the Dashboard, or if I can "pull" this info using the API.
If you go "Organisation/Configuration Templates" it will tell you the number of bound networks.  Subtract this number from 512 and you are done.
