Is there a way to edit preset IPsec policies?
Boyan1
If yes, where do I edit/define these? Thank you everyone!
The answer is no, but what exactly do you want to change? Because with the custom option, you can define the way you need to establish IPsec tunnels.
Boyan1
@alemabrahao Thank you for the quick reply. Totally, I can do custom, however I'm trying to set up this in a future-proof way -- what I want to do is setup custom templates for each unique peer that we need to interface with and then have regular staff just select it from the drop-down instead of messing with the individual parameters of IPsec phases - basically eliminate any room for error by staff who are not exactly the Jedi Master Yoda of VPN; especially on the soil of our VPN peer partners not being very technically savvy either.. Thanks for the unfiltered non-BS answer, nonetheless.
Soichiro-Ono
Hello @Boyan1 .
As you can see, the preset policy cannot be deleted. Let's deal with proxy by properly assigning the authority of those staff.
Managing Dashboard Administrators and Permissions - Cisco Meraki
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
