Is Meraki VPN traffic monitored by USA government? :D
rabusiak
Can someone explain why I'm seeing this weird ip addresses when I check how traffic hops from client connected with VPN to my environment? Connection is terminated on vMX in Azure. Also, I use Radius on AD for authentication and same IPs are also shown as NAS ipv4 addresses when user initiates connection:
6.1.54.50
6.182.213.103
Both from Fort Huachuca, Arizona... USAISC Headquarters... 😮
GreenMan
Meraki Alumni (Retired)
Internal addressing (just used within the tunnels)
GreenMan
Actually...   I noticed you're seeing them used for MX authentications to RADIUS too?
Have a look here:   https://documentation.meraki.com/MX/Other_Topics/MX_and_Z-series_Source_IP_for_RADIUS_Authentication
I think maybe you are running the Spoke MX in Single LAN mode?   (Security & SD-WAN > Addressing & VLANs page)     If you change to VLANs it will use a private address you've configured.   That's if you are unhappy with or cannot use the 6.x.x.x   - which would work, provided your central routing takes the return traffic back to the Hub MX.
yaypingworks
Input those addresses in firefox and it will bring you to your concentrator local page. We recently ran into the same deal. Meraki shenanigans
