Internal Website blocked trough Anyconnect
NotKnown
I have a customer who uses an MX85 for an month or 2. It worked fine till now.
Some users use an anyconnect vpn to access an internal page.
That page is working fine for everyone else, but not since this morning for the vpn users.
Most of the time i got an page saying the wait time is expired, and some times i got an meraki page, with the message the specifiek FQDN is blocked.
I can access that same server via RDP and i can ping/trace it, it works fine, so it something else, instead of a firewall rule.
But i cant find anything in the logging.. and doing an realtime log via tools, there also are no blocks.
I added the fqdn's in the whitelist of content filtering and AMP. but no luck...
in the packet trace some tcp retransmissions, but cant really find something what
does anyone has an idea?
NotKnown
After disabling AMP/IPS/IDS it works again.. so far having security..
dont get it why it doest use the whitelist then
Brash
Add the FQDN/IP Address to the Trusted IP Address list and the AMP whitelist under "security & SD Wan -> threat protection
NotKnown
i already put them there. that why i am a little confused why it doesnt work. For now i will it like this, and will try some things this evening so i do bother the users atm.
Still, why isnt there any logging or something in the security center then.
