- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Install custom hostname certificate for AnyConnect on the MX
Has anyone been able to successfully install a custom hostname signed certificate on the MX? I am getting a "Failed verifying Device Cert with the Cert Chain" error message. I do have an open case with support already but wanted to reach out to the community as well.
The last reply I received from support was to make sure that the certificate is PEM encoded. In the CA reply, I did receive the signed certificate with a .pem extension along with the intermediate/root certificate bundle with a .pem extension. I attempted to upload them but still received the cert chain error.
I also converted the .pem to a .cer format using openssl but still received the cert chain error.
openssl x509 -inform PEM -in cacert.pem -outform DER -out certificate.cer
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Meraki *gives* you a public certificate for free. All you have to do is connect to the DDNS name that your MX says it is using, and you'll get zero AnyConnect warnings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I don't know the answer.
I don't bother with custom DNS domains anymore. It's not worth the grief.
Create a custom AnyConnect profile instead. Users never need to see or type the DNS name then. Now you don't care what the DNS name is.
https://www.ifm.net.nz/cookbooks/online-anyconnect-profile-editor.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you for the response.
The issue is the AnyConnect client VPN is using an auto-generated cert currently. This throw a "Security Warning: Untrusted Server Certificate" warning when users connect thru the VPN. I'm trying to remove this message by installing a public CA signed certificate.
I will be deploying a profile as well but wanted to resolve the cert warning issue first.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I wasn't aware of that option. That's great.
The MX is using DDNS. The public domain name is companyname-sitename right now. Do I just change it to vpn.companyname.com if that's what I want to use or should I keep it as is and create a AnyConnect profile with the current domain name? The current domain is companyname-sitename-somechars.dynamic-m.com.
Thank you so much!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you so much, PhilipDAth!
I was able to resolve the cert warning message for VPN using a profile with the dynamic host names of the MX.
https://documentation.meraki.com/MX/Other_Topics/Dynamic_DNS_(DDNS)
https://documentation.meraki.com/MX/AnyConnect_on_the_MX_Appliance/Client_deployment
