If I change local ip address of SPOKE MX , VPN will be down or not ? (New questions added)
AkiraZhang
My customer want to change LAN segment of his SPOKE site.
If I change local ip address of MX by remote operation , VPN connection will be down or not ?
New questions:
Topology:
     MX
 MS1 MS2
1.Is it possible to change MX and MS 's local ip address by remote operation?
   I should change local ip of MS firstly, is that right?
2.If I changed local ip address of them, they will be rebooted until they can registered to Dashboard?
2 Replies 2
jdsilva
If you're using AutoVPN it will be down for a very brief period of time until the Dashbaord can disseminate the new information. You do not need to take any action.
AkiraZhang
Thank you for your reply.
New questions were added:
Topology:
     MX
 MS1 MS2
