I am trying to setup Posture and Provisioning on ISE using MS350 switches. Is CWA/redirect supported on the MS350?
Solved! Go to solution.
Here’s a useful document, https://community.cisco.com/t5/security-documents/how-to-integrate-meraki-networks-with-ise/ta-p/361.... In the introduction it has a compatibility table that lists CWA as supported on the MS devices.
Thanks Bruce, got it to work.
