IP conflict, but notice has same MAC address for both.
BobHarrison
I get this notice about every hour.
The security appliance in the _XX appliance network has detected an IP conflict with two or more devices.
  • The IP 10.1.70.20 is claimed by clients with the following MAC addresses:
  • xx:xx:xx:96
The 2 MAC addresses are identical. Why would this be a conflict?
I check logs and all I see is this one MAC address with this IP and no conflicting entries for other devices on that IP.
Any ideas?
The security appliance might be detecting multiple ARP announcements for the same IP/MAC combination, possibly due to a device flapping between interfaces (e.g., wired and wireless) or a virtual IP or clustering setup where the same MAC/IP is advertised from different ports.
If the device is connected via a link aggregation group, the same MAC could appear on multiple interfaces, confusing the appliance.
Aside from the logs, are you experiencing any other problems? I'm asking because this could just be a false positive.
5 Replies 5
BobHarrison
We were having a problem with the device which is a sign. We got the alerts then. The controller was bad, so we replaced it and it was assigned a different IP and we now get the alerts on the new device. It seems to be working correctly.
We occasionally get the same alerts on a few other devices. Those were laptops that were on Wi-Fi that got plugged in occasionally, so your explanation makes sense for those.
Thanks for pointing out the possible causes. It doesn't seem to have any negative effect, so it may be false positives for the reasons you mentioned. I will consider this answered unless we experiense other issues.
If you are not running a current stable firmware, try upgrading to that.
GIdenJoe
Hey guys, it is important that you check the actual MAC address in the event log!!
It happens many times that one device is using multiple mac addresses that are just 1 digit higher and then that gets pushed to the same dashboard client.  And if that client is identified by it's MAC address then you get that flapping with the same client.
I have seen this behavior many times with Synology NAS devices if they are not using LACP (802.3ad) to load balance their upstream traffic.  Then it continues to send traffic using one mac and the next packet with the next mac.
WaldoBlackwood
This usually points to the same device presenting itself twice on the network, not two different devices. It can happen if a machine has both wired and wireless interfaces active at the same time with the same IP. Virtual machines or containers can also cause this if they bridge through the same MAC. Another possibility is a DHCP issue where the device briefly re-registers and the appliance thinks it is a conflict. Since the MAC is identical, it is likely a logging or detection glitch rather than a true conflict. I would check for dual network connections on that device and reboot it first. If it keeps happening, review your DHCP leases and see if that IP is being renewed repeatedly.
