IGMP with MX64
Antohind
IGMP with MX64
Hi guys,
I have the Meraki MX64 with Meraki ms-220 and talk talk ISP internet connection with youView IPTV.
Everything works as it should except the IPTV channels that I have subscribed too there appears to be an issue with IGMP setup and multicast
Could someone please advise
9 Replies 9
Antohind
Antohind
The TalkTalk youview box connects to port 3 on the Meraki switch have i miss understood the IP setting value for the IGMP interface ??
You can't use IGMP via an MX WAN interface.
Antohind
Is it possible for this to work with Meraki am i just doing something incorrect ?
Antohind
Antohind
IGMP Support on the Cisco Meraki Security Appliance
MX Security Appliances will forward IGMP traffic for a single broadcast domain. It does not forward multicast traffic upstream, between VLANs, or over a VPN.
So that says IGMP is supported within a single VLAN - is that your case?
Like I said, it wont forward IGMP/multicast traffic that originates from the WAN port, which I suspect will be your case.
Antohind
Yes one single VLAN but it is coming in from the WAN 😞 i just configured my ISP router and put the device into passthrough mode and straight away i got my channels working.
I'm really wanting to use the client vpn feature before i drop meraki like a hot potato lol
Is this still possible in passthrough mode ?
Thanks for your help
I don't know about pass-through mode.
