IGMP with MX64
IGMP with MX64
Hi guys,
I have the Meraki MX64 with Meraki ms-220 and talk talk ISP internet connection with youView IPTV.
Everything works as it should except the IPTV channels that I have subscribed too there appears to be an issue with IGMP setup and multicast
Could someone please advise
9 REPLIES 9
Re: IGMP with MX64
Re: IGMP with MX64
The TalkTalk youview box connects to port 3 on the Meraki switch have i miss understood the IP setting value for the IGMP interface ??
Re: IGMP with MX64
You can't use IGMP via an MX WAN interface.
Re: IGMP with MX64
Is it possible for this to work with Meraki am i just doing something incorrect ?
Re: IGMP with MX64
Re: IGMP with MX64
IGMP Support on the Cisco Meraki Security Appliance
MX Security Appliances will forward IGMP traffic for a single broadcast domain. It does not forward multicast traffic upstream, between VLANs, or over a VPN.
Re: IGMP with MX64
So that says IGMP is supported within a single VLAN - is that your case?
Like I said, it wont forward IGMP/multicast traffic that originates from the WAN port, which I suspect will be your case.
Re: IGMP with MX64
Yes one single VLAN but it is coming in from the WAN 😞 i just configured my ISP router and put the device into passthrough mode and straight away i got my channels working.
I'm really wanting to use the client vpn feature before i drop meraki like a hot potato lol
Is this still possible in passthrough mode ?
Thanks for your help
Re: IGMP with MX64
I don't know about pass-through mode.
