I have two seperate sites with the same issue.
Site A - Spectrum internet
1068/40 Mbps Is the purchased and delivered speeds at the ISP modem and Router (I tested myself)
Intrusion detection and prevention - Set to Eitehr Detect or Prevent, Ruleset set to Connecivity, balanced or Security adn the Internet speed drops to 200 Mbps
Site B - Spectrum internet
600/35 Mbps Is the purchased and delivered speeds at the ISP modem and Router (I tested myself)
If I set to off, I hit the speeds that are delivered by the ISP (With the limitation of the MX-67 not able to go over 800 Mbps)
I want to have the protection, but not at a loss of 80% of the internet speed. In otehr manufactures of firewalls usually impact the speed by about 20% max. Please help.
