You can't use NPS with Azure AD. You can only use it if you are AD syncing with Azure, and then it runs against AD. The link with Azure AD is only an extra step for MFA.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_eeac8ad114420","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_eeac8ad114420_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_eeac8ad114420_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_eeac8ad114420_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_eeac8a68b072f","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
