I have a problem accessing a device mx100 via managment port
awadkhider
Just browsing
DarrenOC
Hi @awadkhider
connect your PC to the MX management port via Ethernet cable. Set your PC to get an IP via DHCP then browse to the IP of the default gateway that you’re assigned.
You’ll be asked to enter a username and password. The username is the device serial number. No need to enter a password.
5 Replies 5
DarrenOC
Hi @awadkhider , can you expand on the issue a bit?
Is this a brand new MX fresh out the box?
has it been operational for a while and you want to make a local change?
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
awadkhider
Just browsing
Yes, I have turned it on for a while,on the dashbord ; but I have not made the required settings yet , and i have not done the local settings yet
DarrenOC
Hi @awadkhider
DarrenOC
All ears @presley , do you want my bank account number and sort code?
@DarrenOC I'm sure I have those somewhere, would you like me to share? 😇
