Hub to Umbrella Cloud Traffic Forwarding:
Bindhiran
Hello Folks,
There's a use-case to enable DIA on Hub location to let it pass through Umbrella Cloud. How do we achieve this? The below behavior restricts the communication between Hub to Hub(UMB-SIG)?
Would configuring an Exit-Hub as UMB-SIG on the Hub locations resolve this restriction?
Kr,
Bala
1 Reply 1
I think it just tells you only this location  connects to the umbrella hub.  And if you want other hubs  to connect to a umbrella hub you need to configure them seperate
