How to view subnet masks of WAN interface
michael_h
Hello, I'm looking to be able to pull the subnet mask for WAN interfaces using DHCP. It doesn't look like this is available via API calls. Also it looks like we can only view  the subnet mask for statically assigned IPs in the local status page. Just wanted to make sure I'm not missing anything.
RaphaelL
Hi !
Pretty sure you are right. I had the same frustration couple weeks ago.
michael_h
Thank you @RaphaelL , that's what I needed to know.
KarstenI
I have no real solution, but as a workaround, you could capture the DHCP communication.
