How to increase the bandwidth limit in traffic sharping to more than 100Mbps (currently 5Mbps max)
Tu__Nguyen
Our customer required bandwidth limit for a specific 'localnet' is 100Mbps.
But in the sharping rule dashboard, the bandwidth limit only allow 5Mbps (simple) and 10Mbps (detail mode). How can I increase this maximum limit?
(self-configuration or support help might required?)
Thanks.
2 Replies 2
CptnCrnch
Which MX are you using for this?
You should be able to set this. You get a error? (Note, this is a per client rate for each client in the localnet)
