How to get rid of annoying maintenance notification.
ErnstTFD
The whole of last week I had to click on the maintenance notification for 6th of June every time I opened my Meraki dashboard. Then on the 7th, the notification for the 6th still showed up as well as a new one about the 7th. These have now gone, but today there is a new notification about the 23 of June popping up. This is very irritating because it does not go away once closed. The notification keeps popping up every time I access my Meraki. Is there no way to click it once and never have to see it again? Or am I going to have to look at it every day repeatedly for the next two weeks?
Thank you for any help if possible.
You should have open a support case.
2 Replies 2
ErnstTFD
Will do. Thanks.
