How to config by application or url
Knoxville90
Hello Community,
Do you know if is posible config internet trafic flow preferences with destination over Application/categories/url?. Example, connections to www.youtube.com use WAN1 and www.facebook.com use WAN2.
I´m using an Mx64  with firmware 17.10.2. I was reading documentation Internet flow preferences are src/dst IP/Port only.
CptnCrnch
Exactly as you found out, the SD-WAN Plus license enables you to have application-specific traffic shaping...which works incredibly well. 😉
6 Replies 6
Unfortunately not, just IP or CIDR.
Knoxville90
Continuing with the search, I find that it is possible but using the Secure SD-WAN Plus licensing to have the SD-Internet feature. Which allows me traffic shapping by applications
https://documentation.meraki.com/General_Administration/Licensing/Meraki_MX_Security_and_SD-WAN_Lice...
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
is this correct?
It's new for me, because I've never seen a customer using a Secure SD-WAN Plus license. 🙂
Knoxville90
Thank you for your help, we are looking this solution with a Meraki AM.
CptnCrnch
Knoxville90
Thank you for your help, We are still waiting for the review with the AM of Meraki.
