HI i am getting user complaints about Meraki not connecting to our network
Prakash_blr
When i checked in dashboard i am seeing this error. There is no loose cable it was working fine some time and suddenly facing this issue.
@Prakash_blr You seem to have a large SD-WAN with many peers connected but a few that are not.
Do the failed ones change or stay constant?
If constant what does their VPN connectivity page look like?
It could simply be ISP issues.
5 Replies 5
so this one is green.
what is the status of the other vpn peer?
Prakash_blr
Other side Peer works fine. only remote  Z3 VPn falls to this issue
Does the MX have a public IP on it, or does it site behind another router?
Prakash_blr
It is connected to broadband router. i have asked them to setup a static public ip for that router
