We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hello everyone,
Do you have guide to setup MX HA mode would you please share for me.
Thanks & best regards,
Viet Ton
Solved! Go to solution.
This document should help you:
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Deployment_Guides/MX_Warm_S...
As long as your network is connected/configured correctly, enabling high availability in the dashboard is relatively trivial.
The guide @jbright provided should have everything you need to get started.
Hi Jbright,
Thanks so much
Viet
