Guest Ambassador
Jeizzen
Guest Ambassador
Hi
I'm trying to figure out the complete privilege of a Guest Ambassador
int the doc :
Guest ambassador: User only able to see the list of Meraki authentication users, add users, update existing users, and authorize/deauthorize users on an SSID or Client VPN. Ambassadors can also remove wireless users, if they are an ambassador on all networks. The existence of network templates anywhere in a dashboard organization prevents guest ambassadors from deleting wireless users.
Presented with user management portal only.
My question is does a Guest Ambassador is able to create a new client vpn and authorize it ?
thanks,
DarrenOC
Hi @Jeizzen , the Ambassador can only setup, delete and authorise users.  They can’t configure services such as VPN clients
Jeizzen
Hi UCcert,
But if the client vpn service is already enabled, the admin in Guest Ambassador mode should be able to create and authorize client vpn users ?
thanks ,
DarrenOC
Hi @Jeizzen , are you asking if the Ambassador can add new users and authorise them to use the Client VPN?  If so the answer is yes
Jeizzen
yes
that answers my question
thanks,
