Group Policy – Why is the highest custom bandwidth limit only 100 Mbps?
Shubh3738
Hi Community,
While creating or editing a Group Policy (example: Directors_Access), I noticed that the maximum available custom bandwidth limit is only 100 Mbps.
Earlier, I remember we could set higher bandwidth limits (e.g., up to 1 Gbps or unlimited).
Is there a recent change or restriction in Meraki Dashboard that limits the bandwidth cap to 100 Mbps for Group Policies?
Here’s the screenshot for reference:
Kindly let me know if:
This is a global change, or
Related to specific device model / firmware version ?
IvanJukic
Meraki Employee All-Star
Correct. Do not use the simple mode. That has the slide bar set to 100mbps. Click on details, and you can enter the values like my screenshot.
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
IvanJukic
Hi @Shubh3738 ,
In your screenshot, click on the details link and you can enter the value manually. I tested this in the Lab.
Cheers,
Ivan Jukić,
Meraki APJC
Shubh3738
When I select a custom bandwidth value in simple mode, it automatically sets the value to 100 Mbps, even if I try to enter higher limits.
IvanJukic
Cheers,
Ivan Jukić,
Meraki APJC
Exactly as explained, just click on details and you will be able to set a higher value.
