- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Flow Preferences
I have two ISP: WAN1 and WAN2
I would like to send all activity from my SONOS system through WAN2. So I configured:
192.168.128.87 is the fixed IP of the SONOS Bridge in my system.
Looking at the "Live Usage" in the Meraki App I see that all usage is still through WAN1
In the documentation I read:
Configure the preference similarly to the rule shown below. In this case, the Local IP range of 192.168.128.252/32 is the internal device referenced in a 1:1 NAT rule, and the Preferred uplink is the one using the public IP reference in the same rule.
But here I cannot follow any more, as I am not an IT professional (Home use of Meraki System)...
Do I still have to make a 1:1 NAT rule (or Layer 3 Firewall ?). Can You please give me an example.....
Help very appreciated, and Many thanks in advance !!!!
LD
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If there is an existing cached flow the change does not kick in immediately. Also it only affects not connections - not connections already in existance. Sometimes it takes 10 minutes or so.
If you have the ability to restart your MX - you could do that to force it to kick in.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Many thanks ! I'll give this a try.
So, if I understand well, I do not need any extra NAT or Layer 3 rules.
LudwigD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks again, was very helpful !
LD
