Flow Preferences using URL/Domain as Destination
meraki-newbie
When applying below flow preferences configuration, I couldn't config destination using URL and alert appears when i want to save it
my question is, could Meraki perform to configure Destination using URL/domain using certain menu/configuration? and decide which uplink preferred like my old FS router below :
thank you
2 Replies 2
Brash
Flow preferences can only use IP addresses or subnets for the destination.
There are more routing features available such as application based routing with the SD-WAN plus MX license. However I believe it still does not support FQDN.
Codzima
I ran into the same thing and ended up using IP-based rules instead since domains aren't supported for flow preference. Needed to track the domains to IPs manually, which isn’t ideal.
