Flow Preferences: Way to ensure preferred uplink is actually used?
triumphwalk
Is there a way in the Meraki Dashboard to ensure an SD-WAN & traffic shaping flow preference is actually being used? We have a few preferences created for DNS resolution from certain hosts to use WAN2 specifically. Is there a way to verify this traffic is using WAN2?
Fow internet traffic you can packet capture the internet port when doing a dns lookup. Then look if you see the spesific dns lookup in the capture.
For vpn traffic you can see it at the vpn status page. Uplink decisions
1 Reply 1
