Firewall using FQDN for MS Update
ToDevNull
Dear all,
We are using Meraki MX devices like this :
- Use the autoVPN feature to reach local ressources accross our organization
- The firewall is not allowing the use of the local Internet access
- We would like to allow the MS Update feature by using the Internet access
We configured the firewall like the following.
Is this kind of filtering needs should be implemented like this ?
Is such configuration can allow the MS Update ?
Thanks for any help/comment/remarks.
Rds,
Brash
As with most things Meraki, there's a few ways to implement this.
What you've configured above should be fine provided the URL's and Ports are correct - from a quick Google search it seems that they are.
1 Reply 1
Brash
