Feature Request - Turn off SSID's or all wifi on MX68CW when part of template.
Can I please log a feature request to be able to turn off SSID's or all wifi on a MX68CW that is part of a template. I'm told that currently this is only available on the backend so I need to call or log a ticket.
I need this function as the MX68CW wifi is unable to mesh with the MR33 wifi. It would be great if I could configure this rather than log a call for it.
Thanks!
Accepted Solutions
Re: Feature Request - Turn off SSID's or all wifi on MX68CW when part of template.
Have you also made that wish in your Dashboard? If not, you should possibly go for it too. 🙂
10 REPLIES 10
@superfly  hello i think it will require a long process for you to configure that feature in your dashboard on the mx68cw
I also advice you log a ticket
You should "make a wish" within the dashboard and maybe open a case as well.
To add to this, make sure you do it from the Security & SD-WAN page so that it goes to the right product team 🙂
I did not realize wishes were routed that way. It makes sense in retrospect. Thanks for the heads up, @DavidLowe!
Unfortunately you can't make a wish on the dashboard anymore. At least I can't see it anymore on my dashboard. That's why I posted it here and I added it to the ticket I logged to see how I could turn the wifi off.
I wish I could do that, 'make a wish' is no longer listed for me.
Not even when scrolling down to the bottom? Then there should be a "Make a wish"-button.
At least, it's there for me, but perhaps I've not used all of my three wishes for today. 😉
hm, its not unter help, just scroll down tothe end of the page, it should be there.
Now I feel dumb! I could've sworn it was in the help menu. Anyway, I will make a wish now 😄
Thanks for the headsup!
