False reporting, lost VPN from Spoke to HUb after upgrade to MX 18.211.2
Steve_PF
anyone seeing lost of tunnel from Internet 2 on the spoke devices after upgrading their MX to 18.211.2? Seems to be a false reporting.
Thanks,
Steve
5 Replies 5
Inderdeep
Can you check if it is showing enabled after upgrading
> Configure > Site to site VPN?
www.thenetworkdna.com
Steve_PF
Yes, it is enabled.  Also we are using Template configuration; it didn't change after the upgrade.  I also confirmed the tunnel is up from the hub point of view and I see the tunnels packets traffic passing.
Inderdeep
Cisco ticket required then, seems no issues on the configuration side. We had that kind of issue 2 years back where configuration changes after the upgrade, seems like bug that time .. But recommending Cisco ticket
Steve_PF
Yes already have a ticket open.  but since, I pretty much lost (according to the portal) all tunnel on WAN 2 on all my spokes (around 82 sites).
Kinda cool bug.
I have a client where it i reporting 100% packet less on AutoVPN on WAN2 - but traffic is passing over AutoVPN on WAN2 just fine.
