External LTE antenna with cable for MX67C
Frank_Haugen
Has anyone tried an external antenna with cable for MX67C? Will that work?
jdsilva
Yup, it will work, but you should be mindful of the cable loss when doing this. If you're using a cheap cable with high loss you're going to find very poor performance on any meaningful distances. Even with a low loss cable I would try and keep the run as short as possible.
jdsilva
Alex-G
Does Meraki sell these for the MX67C? We are needing to use extentions with the deployments we are currently working on.
BrechtSchamp
No they don't.
