Explain license co-term meraki
QuyLe
I have read the description of Renew my Dashboard license (Renewal) according to the attached link. Before it was 364 days, but after adding the license we have 411 days, adding 48 days. How to calculate 48 days, can you explain in detail?
https://documentation.meraki.com/General_Administration/Licensing/Meraki_Licensing_-_License_More_De...
@QuyLe in the co-term model there is one consistent end date for every device in the organisation. Each licence counts as a number of 'points' and when you add them up you get the end date.
For example: Org has one wireless AP with 6 months left and adds one more wireless AP
6 months + 12 months = 18 months.  18 months / 2 devices = 9 months each
If the end point was the end of December 2022, it would now be the end of March 2023.
Different devices add more or less 'points'
QuyLe
I understand what you say, but I can't understand for example Renew my Dashboard license (Renewal)  in the attached link.
@QuyLe I looked at the documentation in the link and you are absolutely right, it is very confusing!  It is two different networks (the before and after), the "renewed" one has an MS225 and an MX400 in place of the MS120 in the before.  A one year renewal would actually show an end date simply going 1 year forward.  I'll report the issue with the documentation.
Ryan_Miles
It's showing what happens when you apply a renewal that doesn't contain the devices previously licensed. The renewal key shown has: MS225-48, MX100, MX400, MR. Applying that as a renewal will result in eliminating the MS200-8P in the before picture.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
