Exit Hub Configuration API
VinoyMohan
Hi All,
Is there an existing API which we can use to define the Exit Hub option in the Meraki dashboard for a hub Network. Thanks in advance.
Br
Vinoy
Brash
VinoyMohan
Hello Barsh, Thanks for your response.
But this doesnot have an option to set the Exit hub, i am not sure i can see that in the API. There is only 1 option to select multiple Hubs and not the Exit hub.
Brash
I haven't tested but I assume when you select Hub as the mode, the hubs listed in the JSON request are interpreted and configured as Exit Hubs.
GreenMan
Meraki Alumni (Retired)
I'm interested in why you'd want to do this?   Using the API implies a significant scale:   lots of MXes configured as Hubs.   Given the quantity of tunnels you end up with, with a full mesh of Hubs, for example, these things often don't go well together.   If you only have a handful of Hubs (i.e. you use Hub and Spoke setup - which is what's recommended, in order to scale, generally) you'd normally configure each of them through the UI.
