Ethernet port carrier change device: port0, carrier: false
IanHocking27
Hello.
I have an MX64 connected to an MS220-8P.
LAN port 4 on MX64 is connected to LAN port 8 on the MS.
about 20m apart.
Every day or so i get the message in the Subject field in the event log for the MX. Nothing in the event log for the MS.
The switch goes off-line.
I unplug the patch lead on the MX and reboot the MS, and can get the switch back online again.
Spanning tree is turned off. simple network.
I set both ports to "100 Megabit full duplex (forced)" thinking it might be the auto-negotiation causing this.
Still happens.
Anyone got any ideas?
thank you!
2 Replies 2
Port0 is the WAN/ internet1 interface
It looks like a physical issue. Try exchanging the cable.
