Dual MX for HA with load balancing
Rakesh_Kumar
Hi All, I am looking for new Wireless Network design for my office which should include Hardware failure resiliency with two WAN for load balancing feature. I am not sure if both these feature can be achieve with single Meraki design . Can anyone guide if internet load balancing can be achieve with HA resiliency ?
you can use 2 wan ports and load balance on the primary (or backup) mx.
But only 1 mx can be active at the same time.
Rakesh_Kumar
@ww  thank you for replying.
in that case do i need 3 WAN connection, Two in primary MX for load balancing and 1 WAN on spare MX for resiliency ? Do you have any network design which you can guide anyway ?
Check the general best practices.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
KarstenI
Typically both MXes are connected to both ISPs. Two MX, two ISPs (with at least /29 subnet) and you need to make sure that both MX devices can physically connect to both ISP. For this 2 switches are often used between the MXes and ISP routers.
