Download Network Usage?
TonyLDI
We have a Meraki MX84.  I am wondering if there is a way to download the data that is used to generate the network usage chart that display along the top of the dashboard.  I have a specific client that I would like to take a deeper look at over the past week, but when changing the display to a week rather than a day or 2 hour time interval, it becomes more generalized and I'd like to be more specific and drill down.
Thanks,
Tony
3 REPLIES 3
NolanHerring
Re: Download Network Usage?
You should be able to export to excel in the top right corner
Nolan Herring | nolanwifi.com
TwitterLinkedIn
when you have Hostname visibility on "report specific hostnames" and the network wide > traffic analitics or the Org > summary report is not specific enough you can try use export data with netflow to a other tool (for future use).
pdundon
Below is a link to the Meraki documentation as well. Hope the reference helps.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Hostname_Visibility
