Download Network Usage?
TonyLDI
We have a Meraki MX84.  I am wondering if there is a way to download the data that is used to generate the network usage chart that display along the top of the dashboard.  I have a specific client that I would like to take a deeper look at over the past week, but when changing the display to a week rather than a day or 2 hour time interval, it becomes more generalized and I'd like to be more specific and drill down.
Thanks,
Tony
NolanHerring
You should be able to export to excel in the top right corner
Nolan Herring | nolanwifi.com
TwitterLinkedIn
when you have Hostname visibility on "report specific hostnames" and the network wide > traffic analitics or the Org > summary report is not specific enough you can try use export data with netflow to a other tool (for future use).
pdundon
Below is a link to the Meraki documentation as well. Hope the reference helps.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Hostname_Visibility
