Hi @Zeeshan786 yes you can. Section on Non-Meraki VPN Peers
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Settings
You can create Site-to-site VPN tunnels between a Security Appliance or a Teleworker Gateway and a Non-Meraki VPN endpoint device under the Non-Meraki VPN peers section on the Security & SD-WAN > Configure > Site-to-site VPN page. Simply click "Add a peer" and enter the following information:
- A name for the remote device or VPN tunnel.
- What IKE version to use (IKEv1 or IKEv2)*
- The public IP address of the remote device.
- The Remote ID of the remote peer. This is an optional configuration and can be configured to the remote peer’s UserFQDN (e.g. user@domain.com), FQDN (e.g. www.example.com) or IPv4 address as needed.
- Which of these values you use is dependent upon your remote device. Please consult its documentation to learn what values it is capable of specifying as its remote ID, and how to configure them (e.g. crypto isakmp identity for ASA firewalls)
- The subnets behind the third-party device that you wish to connect to over the VPN. 0.0.0.0/0 can also be specified to define a default route to this peer.
- The IPsec policy to use.
- The preshared secret key (PSK).
- Availability settings to determine which appliances in your Dashboard Organization will connect to the peer.
