Disestablishing HA
Dannygere
Disestablishing HA
With 2x Mx84 in HA.  Is there a correct way to break the HA ?
No longer need the 2 MX’s only 1 needed but I want to disestablish correctly.
2 Replies 2
AjitKumar
Hi @Dannygere
I am not aware of a best practice document from Meraki on De-Establishing HA.
I believe you may disable HA from Appliance Status page (The sessions established on VIP will be disconnected) and remove the device from the network.
However Aaron published a well written document on the functionality of Warm Spare in Meraki.(Worth reading)
https://www.willette.works/mx-warm-spare/
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
jdsilva
I would probably power off the secondary, and then remove the secondary from the dashboard. Last step is physically remove the device.
I would suggest caution with this guide. There are many incorrect assumptions made, and warm spare does not always work the way the author suggests.
