Disaster recovry between tow site
jOMeraki2
hi all , i have tow sites connected using auto VPN, i have hyper v replication between two sites i want to do disaster recovery if the server in the HQ is damaged I want all vm up in the branch with the same ip how will meraki help me I see a lot of topic for data center failover i need the best practice
1 REPLY 1
For that kind of setup - in the event you wanted to failover between sites, you would need to re-configure the MX at the branch to use the same IP addressing as at HQ (or change the VMs to use IP addresses consistent with the scheme at the branch).
