Block External IP Address
ED3573
How do I block an external IP address using a Layer 3 rule? I have created a network object and group but when I try to added to the source and if I give it on the destination field the rule doesn't work at all.
"Does not apply to any configured local or VPN subnets in the source field"
Is there anyway to create rule to block specific external IP address to not allow to get to internal resources? or this is not possible with the NAT rules.
6 Replies 6
BrandonS
I'm pretty sure I just replied to your Reddit post 😉
You don't need to do anything.  External IP addresses cannot reach any internal resources unless you explicitly allow it with firewall rule/port forward.
ED3573
Thanks Brandon,
Well that's the thing we have a NAT rule for a webserver but I want to block an specific address, but the only thing I see is "Allowed remote IPs" over the NAT rule not block.
I have geoblock in place so what happens if I have an allowed country and one specific address from this allowed country is trying to brute force the web server?
BrandonS
I don't think there is a way to block a specific address or subnet in a NAT rule.
You could drop them in the web server though, right?  And I guess you could put something upstream with ACL's to block specific IP addresses.
Do you have advanced security license?  You maybe able to do something there.
I have a similar situation with a FTPS server I maintain to send customer backups to.  It uses port 22 and gets hammered all day, every day.  I configured my server to block specific addresses and it also has a feature to auto block multiple failed attempts.
BrandonS
I just had an idea actually.  Make a rule specifically allowing that IP and point it to a "black hole" like an IP address in a VLAN that goes nowhere and has access to nothing.  If you can move the rule to the top of the list it may (should?) trigger first and have the effect of blocking.
ED3573
I cannot add public IP addresses using Layer 3 as source because they are not configured as a Subnet.
I don't know if this is the way, we have the Advance Security License, I did the following test I added a public IP into this L7 Rule
Proceed to access and it worked I wasn't able to access the web server from that specific public IP, would be nice if we had an official method of doing it with layer 3 or in the NAT were a clause block for doing it.
Thank you.
You should be able to create an outbound firewall rule from the devices internal IP address to the public IP address you want to block, denying the traffic.  This wont stop the traffic coming in, but I think it might block the return traffic (you need to test this to verify).
Another method I haven't tried - but you could try creating a static route for the IP address you want to block and route it using the black hole method - to a local IP address on the LAN that does not exist.
RPF should caused packets that come in from the Internet to be blocked.
