Disabling Firewall Rules
navysubvet
On my non-Meraki FWs, I've always been able to toggle certain rules on/off, as needed. I'm not seeing the option on the MX105. Does that option exist, and if so, where? Maybe I'm overlooking it...
Unfortunately you cant.
You could move rules under a more global rule that would allow traffic.(below a allow any any)
Or you could use api to get and put to speed things up.
3 REPLIES 3
It does seem such an obvious feature, doesn't it?
Just like having definitive/absolute line numbers for rules 🙂
